comeinzo este tema con la finalidad de ordenar en un lugar los videos de sap2000, ETABS, etc que existan
yo tengo los siguientes:
VIDEOS SAP2000
Introductory Tutorial (19 min)
Bridge Modeling (21 min)
P-Delta Analysis (10 min)
Tension Only Bracing (4 min)
Drawing/Drafting Controls (5 min)
Selection Options (6 min)
Area Edge Constraints (3 min)
Tabular Data Input (6 min)
Formatting Tabular Data (6 min)
Mass & Modal Analysis (5 min)
Response Spectrum Analysis (4 min)
Time History Analysis (5 min)
Time History Output (3 min)
Cables (19 min)
Gap Elements (16 min)
Tendons (10 min)
Section Designer (10 min)
Custom Report Writer (7 min)
Modeling Solid Objects (3 min)
Nonprismatic Sections (5 min)
Cardinal Points (9 min)
Static Pushover Analysis (6 min)
Nonlinear Staged Construction (6 min)
Sequential Bridge Construction (23 min)
Dynamic Vehicle Loading (7 min)
Wave Loading (3 min)
Power Spectral Density Analysis (10 min)
FWP to SAP2000 Interface (7 min)
Application Programming Interface (13 min)
que se pueden descargar de http://www.csiberkeley.com/Support_WL_SAP.html
VIDEOS ETABS
Introductory Tutorial (27 min)
Drawing/Drafting Controls (9 min)
Staggered Trusses (13 min)
Modeling Shear Walls with Openings (4 min)
Designing Shear Walls with Openings (6 min)
Shear Wall Design Options (6 min)
Wall Meshing (6 min)
Steel Frame Optimization for Displacement (4 min)
Linear Ramps (4 min)
Radial Ramps (2 min)
Concrete Frame Design (7 min)
Composite Floor Beams (7 min)
Foundations – ETABS to SAFE (6 min)
Modeling with Section Designer (11 min)
Nonlinear Sequential Construction (4 min)
Panel Zone Deformations (6 min)
Auto Edge Constraints (8 min)
Sections Cuts (2 min)
CIS/2 Step File Export (9 min)
que se descargan de http://www.csiberkeley.com/Support_WL_ETABS.html
y los de construaprende que estan en http://www.construaprende.com/csi/etabs/videos_1/
VIDEOS Tutoriales
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 20 invitados
