En la version v10.2 del sap2000 viene para definir masas en mass source y nos traetres opciones pero en realidad no se yo a que se refieren cada una de ellas así como los factores que debo de introducir me gustaria que alguien me tratara de explicar.
Por otra parte que diferencia hay entre este modo de asignarla y el de asiganarle a un punto una cierta masa
Deseo saber como introducir masas en sap 2000 v10.2
temahugojpv
- ReneM
En el tópico Mass Source aparece explicado.
Espero te ayude.Mass Source
Form: Define Mass Source
Use the Define menu > Mass Source command to access the Define Mass Source form and specify how SAP2000 should calculate mass for the model. In SAP2000 mass and weight serve different functions. Mass is used for the inertia in dynamic analyses, and for calculating the built-in acceleration loads. Weight is a load that you define and assign in one or more load cases (see the topics in the Assign - Area Loads, Frame Loads, Cable Loads, Tendon Loads, Joint Loads, Link Loads, and Solid Loads books of this Help), which can then be applied in one or more analysis cases.
Mass Definition. Choose how to define the mass of the structure using one of the following options:
From Element and Additional Masses option. This is the default. With this option, the program uses the following mass specifications:
Mass density specified for materials
Additional line mass assigned to frame or cable objects
Additional area mass assigned to area objects
Mass specified for link properties
Mass assigned directly to the joints
From Loads option. With this option, mass may be calculated from a scaled combination of load cases (see Define Mass Multiplier for Loads, below). The absolute value of the net load acting in the global Z direction is divided by the acceleration due to gravity, in the current units, and is used for the mass in the three translational directions.
From Element and Additional Masses and Loads option. This option is a combination of the other two options wherein mass is defined from mass specifications and from scaled combinations of load cases.
Define Mass Multiplier for Loads. If the From Loads or From Element and Additional Masses and Loads option was selected for Mass Definition, enter a combination of one or more load cases in the table using the Add, Modify, and Delete buttons. Those load cases will be scaled by the specified factors and then are added together to determine the mass. Do not include the acceleration as a result of gravity in the scale factors; the program will do that automatically.
temahugojpv
Gracias por su respuesta de hecho me ayudo bastante, puesto que al parecer la mas idónea es la opción en donde se incluye al elemento y asu vez toma encuenta la carga a considerar, sin embargo para el caso más específico de México, cuáles serían los factores que debo aplicar si yo por ejemplo considero que tengo actuación de carga muerta, viva máxima e instántánea. Me surge la pregunta se debe de considerar en este caso la carga máxima o nada más la muerta e instántanea así como si los factores serían el de 1 para los casos.
Reyner
Eso dependera de lo que considere el codigo mexicano, para definir el peso de la estructura, es decir de que porcentaje de carga viva que participe para definir la masa,que dependiendo de la importancia de la estructura pudiese llegar a uno, sin embargo cuando definas la masa por from loads, tambien tienes que incluir los coeficientes de las cargas muertas,generalmente es 1
Espero que te sirva de algo.
Simplemente ingresas a DEFINE MASS SOURCES:
de ahi colocas CM EL VALOR DE 1, PARA CARGA VIVA COLOCAS 0.50 o 0.25 dependiendo si es una edificicacion importante o comun, dependiendo de la norma sismoresistente de tu pais, por ejemplo en el Peru, DISEÑAMOS LAS ESCUELAS COMO EDIFICACIONES IMPORTANTES, ENTONCES COLOCAMOS EN CARGA VIVA 0.5 (QUE REPRESENTA EL 50% DE LA CARGA VIVA).
ESPERO HABERTE AYUDADO Y NO CONFUNDIDO.
temahugojpv
AGRADESCO SUS COMENTARIOS CON RESPECTO A MI CUESTIONAMIENTO ME HAN SIDO MUY UTILES
- 646 Vistas
Último mensaje por Hexia Securite
