Este programa es bastante interesante y calcula las propiedades geométricas (áreas, inercias, centroides, etc.) de cualquier tipo de polígono en el plano XY. Está desarrollado en C# (CSharp) y su algoritmo está basado en el Teorema de Green.
Es muy fácil de usar, funciona sobre Windows XP y necesitas tener .Net Framework 2 instalado.
LINK: http://sourceforge.net/projects/secciones/
Aquí la descripción del programa en inglés:
ERA-Soft Secciones - Section Properties Calculator (FREEWARE)
Engineering calculator that computes geometric properties (area, centroid, moment of inertia, etc.) of any polygon in XY plane (Polygonal section). This tool is developed with C# (CSharp) and it's based on Green's Theorem.
The following properties are calculated:
About XY axis:
• Area
• Centroid (x,y) coordinates
• Moment of Inertia about X-axis (Ixx)
• Moment of inertia about Y-axis (Iyy)
• Product of Inertia (Pxy)
• Polar Moment of Inertia (Jo)
• Radius of gyration about x-axis (Kx)
• Radius of gyration about y-axis (Ky)
• First Moment of Area about X-axis (Mx)
• First Moment of Area about Y-axis (My)
About X'Y' axis (centroid axis):
• Moment of Inertia about translated X'-axis (I'xx)
• Moment of Inertia about translated Y'-axis (I'yy)
• Product of Inertia about translated axis (P'xy)
• Polar Moment of Inertia about translated axis (Jo)
• Radius of gyration about translated X'-axis (Kx')
• Radius of gyration about translated Y'-axis (Ky')
And also:
• You can graph any section perimeter
• User-friendly interface
• Incredibly fast calculations
• Accepts any imaginable section defined using lines (polygon) Graphical display of centroid location
• Graphical display of centroid location
• Freeware !!!
Works on Microsoft Windows XP. You will need .Net Framework 2 installed before.
Link: http://sourceforge.net/projects/secciones/
Calculador de Areas, Centroides e Inercias de Secciones FREE
- ReneM
Hola eriveraa, tu aplicación está muy bien y puede ser de mucha ayuda para el trabajo en una ofcina, sólo me permito hacer unas pocas sugerencias para aportar:
1.- Agregar un pequeño help que indique alguna ayuda, por ejemplo si los contornos internos se consideran como perforaciones del contorno externo (creo que así es).
2.- Podría existir la opción para que el usuario elija la cantidad de decimales en que desea desplegar la información salida.
3.- Agregar los módulos W de la sección, útil para secciones de acero.
4.- Interacción con otras aplicaciones, ejemplo:
4.a) leer los datos (x,y) desde una planilla Excel.
4.b) leer las polilíneas desde AutoCAD, ya sea pichando o importando un DXF.
Espero que sea un aporte.
El nuevo website con información adicional y programas es http://secciones.3biznet.com
Eduardo
Eduardo
Hola
Favor de no repetir el mismo mensaje, en todos los Sub Foros.
Este mensaje se cierra, ya que ya esta repetido en:
http://foros.construaprende.com/calcula ... p9113.html
Usuarios navegando por este Foro: Majestic-12 [Bot] y 31 invitados
