Senores quiero hacer una consulta en el formulario que adjuto , quisiera saber si la opcion encerrada en en un circolo rojo , para el diseno en acero estructural,
quisiera sabes si dicha opcion controla las logitudes no arriostradas de vigas o columnas o es en general para un elmento "frame " ya sea horizon tal o vertical.
LONGITUDO NO ARRIOSTRADA
- yucapareja
si....
El maximo valor es 1.0 (es una relacion)...
GUTI de la ayuda del programa en este caso SAP2000, imagino que para el ETABS es igual, esto es para estructuras metálicas.
Unbraced length Ratio (Major)
Unbraced length factor for buckling about the frame object major axis.This item is specified as a fraction of the frame object length.Multiplying this factor times the frame object length gives the unbraced length for the object.Specifying 0 means the value is program determined.
For symmetrical sections major bending is bending about the local 3-axis.For unsymmetrical sections (e.g., angles)major bending is the bending about the section principal axis with the larger moment of inertia.
Unbraced length Ratio (Minor)
Unbraced length factor for buckling about the frame object minor axis.This item is specified as a fraction of the frame object length.Multiplying this factor times the frame object length gives the unbraced length for the object.Specifying 0 means the value is program determined.
For symmetrical sections minor bending is bending about the local 2-axis.For unsymmetrical sections (e.g., angles)minor bending is the bending about the section principal axis with the smaller moment of inertia.
Unbraced length Ratio (LTB)
Unbraced length factor for lateral-torsional buckling for the frame object.This item is specified as a fraction of the frame object length.Multiplying this factor times the frame object length gives the unbraced length for the object.Specifying 0 means the value is program determined.
Y complemento lo que dijo yucapareja estos valores son porcentuales (relación). Lo demás es teoría de la norma en uso.
Slds.
Slds.
- yucapareja
No entiendo que mas quiere que te diga? tu pregunta fue clara y precisa:GUTISLASH escribió:si que .... podrias ser mas especifico.....
"dicha opcion controla las logitudes no arriostradas de vigas o columnas o es en general para un elmento "frame " ya sea horizon tal o vertical"
Si las controla... y es una relación no un valor, es decir si tienes igual a 1.0 significa que considera toda la longitud del miembro, si es 0.5 considera la mitad...
Espero te ayude por que mas que eso no se que decirte...
[quote]Senores quiero hacer una consulta en el formulario que adjuto , quisiera saber si la opcion encerrada en en un circolo rojo , para el diseno en acero estructural, quisiera sabes si dicha opcion controla las logitudes no arriostradas de vigas o columnas o es en general para un elmento "frame " ya sea horizon tal o vertical.[quote]
Que actitud la tuya de verdad!, eres grosero con las personas que tratan de darte la respuesta a tu pregunta, y de paso nos gritas!. Si lees la ayuda del programa te das cuenta que te dice que son esos factores y para que se utilizan sin necesidad de venir a preguntarlos a ningún foro.
Que quieres que te digamos? que sí es para modificar la longitud no arriostrada de los elementos frame, bien sean vigas o columnas.
Te lo explico como se lo explicaría a un niño de preparatoria a ver si así lo entiendes...
El programa, bien sea SAP2000 o ETABS, tiene por defecto el valor de 0 con lo cual el determina automáticamente el valor de la longitud no arriostrada. Si cambias este valor por medio de los overwrites, le dices al programa donde esta arriostrado el elemento bien sea por su eje mayor o menor. Este valor es un porcentaje de la longitud real del elemento en cuestión dado como una fracción (que es justamente lo que te explico yucapareja), un valor de 0,5 le dice al programa que la viga o columna tiene un arriostramiento justo en el medio de su longitud. Y como te lo dijo Yucapareja no puede ser mayor que 1 porque sino el programa entiende que la viga/columnas esta arriostrada fuera de su longitud, cosa que no puede ser nunca cierto y lo mas probable es que te marque un error.
El SAP y el ETABS tienes 3 factores de longitud no arriostrada para modificar manualmente:
Unbraced length Ratio (Major) Factor de Longitud No Arriostrada para Pandeo. Cuando se arriostra al elemento por el eje de mayor Inercia
Unbraced length Ratio (Minor) Factor de Longitud No Arriostrada para Pandeo. Cuando se arriostra al elemento por el eje de menor Inercia
Unbraced length Ratio (LTB) Factor de Longitud No Arriostrada para Pandeo y Torsión. Cuando se arriostra al elemento por el eje de menor Inercia.
Bueno si aun así no lo entendiste me dices y busco la forma para explicártelo mucho mejor.
Si te nace me lo agradeces sino pues bien ni falta que me hace ni tu falta de respeto-educación, ni tus agradecimientos.
Y descuida que si en otra oportunidad necesitas que te ayude en algo, pues sabe que te la daré sin importar que tu actitud sea tan mala GUTI.
estoy en contra de los problemas, pero este tipo de ingenieros, no funcionan, son un fracaso, de ahora de en adelante respondere, solo preguntas del sap, etabs, las academicas deben buscarlas en los libros.
GUTISLASH este tema ya se trato en el siguiente post en el cual según veo participaste también con una pregunta.GUTISLASH escribió:Ya que no te importa ayudarme , este factor es igual al K de la formula Kl/r, que esta en el retglon inmediatamente inferior al Unbraced length Ratio (LTB)
El forista FYU explico de manera magistral todo este tema de los factores Cm, K, L y Cb así como también la forma como debemos interpretar los datos y tablas del SAP/ETABS.
http://foros.construaprende.com/diseno- ... t2127.html
- josedecaracas
Hola colegas. Necesito que me ayuden a decidir algo respecto a la longitud no arriostrada de una viga metálica. Resulta que los techos livianos de galpones industriales o de grandes almacenes pueden apoyarse normalmente en vigas metálicas que perfectamente cumplen con requisitos de resistencia a flexion pero que muchas veces no cumplen con normas que dictan que KL/R debe ser menor de 200. Mi duda es poder saber hasta donde un techo liviano ofrece suficiente rigidez como para reducir el el programa ETABS la longitud lb para que cumpla con esa norma ya que de lo contrario hay que aumentar la sección de la viga demasiado para las pocas cargas a las que esta sometida.
A evaluar estarían desde los techos ultralivianos como las laminas sencillas de aluminio acanaladas de muy poco calibre hasta los techos de paneles conformados por dos laminas acanaladas rellenas de algún tipo de poliuretano u otro material aislante.
Gracias por su aporte.
El que tenga algun criterio que pueda ayudarme le agradeceria mucho me envíe un correo a torita500@hotmail.com
Buenos días josedecaracas,
El requisito de esbeltez al que haces referencia "kl/r < 200" aplica únicamente a miembros comprimidos. Las vigas de techo no entran dentro de esta clasificación y por consiguiente no debes preocuparte por cumplir con esta relación de esbeltez.
Por lo general en el diseño de vigas para soporte de techos livianos (correas de techo), se asume que la cubierta de techo no provee soporte lateral adecuado y en consecuencia se diseñan a flexión considerando una longitud igual a la separación entre pórticos para pandeo lateral torsional.
Otro aspecto que debes tener en cuenta es la flexión por el eje menor de la viga (debido a que esta por lo general está inclinada). Para controlar o reducir esta flexión se suele usar tensores o tirantes (llamados también tirantillas), que no son más que barras lisas roscadas en sus extremos que enlazan las correas lateralmente. Sin embargo, estos tirantes no deben ser considerados como arriostramientos para reducir el pandeo lateral torsional de la viga ya que los mismos difícilmente podrían prevenir la rotación de la sección.
Te adjunto un ejemplo de diseño de una correa de techo aplicando la especificación AISC 360-10. Saludos,
- josedecaracas
Muchas gracias por la información...
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 18 invitados
