Normativa Grout
Buenas un saludos a todos, quisiera saber si alguien aquí tiene la NORMA COVENIN 2826-08, el grupo de normas de 2825 al 2830 es de grout, y me interesan porque estoy realizando mi tesis de este material y cuento con la normativa covenin pero del año 91, un poco vieja, muchas gracias por su tiempo.
Tengo entendido que en Venezuela se pueden bajar gratis las normas COVENIN, yo mismo he bajado varias para comparar.
http://www.sencamer.gob.ve/sencamer/action/normas-find
- yucapareja
No sabia que habian actualizado esas normas, pero te recomiendo las normas PIP STS03600 y PIP STS0601, son normas americanas industriales que tienen especificaciones del grout sea cementicio o no.
Las normas gringas aplicables serían entonces:
ASTM C531-00(2005) Standard Test Method for Linear Shrinkage and Coefficient of Thermal Expansion of ****** Resistant Mortars, Grouts, Monolithic Surfacings, and Polymer Concretes
ASTM C579-01(2006) Standard Test Methods for Compressive Strength of ****** Resistant Mortars, Grouts, Monolithic Surfacings, and Polymer Concretes
ASTM C827-10/C827M-10 Standard Test Method for Change in Height at Early Ages of Cylindrical Specimens of Cementitious Mixtures
ASTM C882/C882M-10 Standard Test Method for Bond Strength of Epoxy Resin Systems Used With Concrete by Slant Shear
ASTM C1181-00(2005) Standard Test Methods for Compressive Creep of ****** Resistant Polymer Machinery Grouts
ASTM C1090-10 Standard Test Method for Measuring Changes in Height of Cylindrical Specimens of Hydraulic Cement Grout
ASTM C1107-11/C1107M-11 Standard Specification for Packaged Dry, Hydraulic Cement Grout (Nonshrink)
ASTM C942-10 Standard Test Method for Compressive Strength of Grouts for Preplaced Aggregate Concrete in the Laboratory
ASTM C109-11/C109M-11 Standard Test Method for Compressive Strength of Hydraulic Cement Mortars (Using 2 in. or [50 mm] Cube Specimens)
ASTM C1437 - 07 Standard Test Method for Flow of Hydraulic Cement Mortar
ASTM C939 - 10 Standard Test Method for Flow of Grout for Preplaced Aggregate Concrete (Flow Cone Method)
ASTM C 1339-02 Standard Test Method for Flowability and Bearing Area of ******-Resistant Polymer Machinery Grouts
Pero para fines constructivos se agrupan en:
ACI 351.1R-99 Grouting between foundations and Bases for Support of Equipment and Machinery.
si bueno las del 91 las tengo todas pero las del 08 aun no aparecen alli por eso preguntaba, me ire a las gringas como ustedes dicen, otra pregunta no se si saben que segun la forma de la linea de falla para probetas cilindricas se deduce un tipo de falla (por apoyos, por corte, por torsion, etc,etc) en morteros (moldes cubicos) aplica lo mismo? podrian servirme esas mismas normativas que para los moldes cilindricos? gracias a todos nuevamente
Pues teóricamente debería ser aplicable la forma de la falla, sin embargo, por el tamaño del agregado la falla es más frágil y lo más probable es que se te desmorone todo, al menos a los 7 días.
- Energetic001
Tal vez esta información sobre las normas astm te pueda ayudar:
http://www.ingenieriadepetroleo.com/200 ... ratis.html
- 8329 Vistas
Último mensaje por pacomase
