[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios" [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) Andamios con Sap2000 - Foros Ingeniería Civil
Soy nuevo en el cálculo estructural y estoy haciendo un diseño de andamios Rotax plus con sap2000. y mi primer problema es que la estructura es de acero galvanizado y no encontré las especificaciones técnicas, para la asignación del material en Sap.
Mi segundo problema es saber si las restricciones en los apoyos que estoy colocando son correctas.. ojalá me puedan ayudar...
Muchas Gracias
nunca he diseñado andamios, pero se puede tratar de resolver como marcos espaciales, ya que como armadura no sea tan adecuado el análisis porque como las cargas no estarán directamente sobre los nudos, habrá flexiones en las elementos horizontales, ya no se cumple la condición de armadura.
Esto nos lleva a que como tienes restricciones en algunos nudos, es como si esos nudos descargaran las fuerzas hacia algún otro apoyo, y en mi opinión eso no es correcto, ya que el andamio no todas las veces se podrá apoyar también sobre los muros o columnas, que en ese caso si sería válido de alguna forma restringir el movimiento de los nudos.
Los apoyos parece que analizando un poco la situación real, es correcto que sean pasadores, ya que las llantas del andamio al ponerles el seguro no deben deslizarse para ningún lado, sin embargo no hay anclaje con el suelo y por eso no se transmiten momentos. Ya con las reacciones diseñarías los pasadores.
Te falta arriostrar del otro lado y sería bueno si lo puedes arriostrar transversalmente. Estas riostras o diagonales las deberías liberar también de fuerzas cortantes, ya que sólo se usan como puntales para mantener las piezas unidas y como en un edificio, para ayudar a contrarrestar los deslizamientos laterales.
Si le modelas los escalones, esos sí los restringes sólo de momentos flectores, porque ahí si hay fuerzas cortantes y tal vez alguna muy pequeña torsión.
Esa es mi opinión, tal vez otro compañero sabrá mas del tema.
Sobre las especificaciones consulta catálogos de fabricantes de acero, ahí te ponen las propiedades físicas y mecánicas.
