[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios" [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) modelo de pedestal y reacciones al cimiento - Foros Ingeniería Civil
Solo Temas sobre Safe. Programa Ideal para Cimentaciones.
Luego de leer las discuciones sobre el diseño de los pedestales de las fundaciones , llegue a la conclusion de agregar un nuevo piso en el modelo de etabs y agregar un muro tipo pedestal empotrado para analizar los esfuerzos.
Y luego las reacciones de el pedestal empotrado irian a la cimentacion. ¿Que opinan de esto? Creo que mientras la cimentacion sea rigida se justifica sin ningun problema.. ¿cierto?
Espero aun no sea tarde, respondere esperando que te sirva y que un forista con mas experiencia comente sobre el metodo. Puedes realizar los siguiente:
1.- En el ETABS o SAP puedes modelar Superestructura e Infraestructura en el mismo modelo. Puedes agregar un Nivel (ETABS) y dibujar a partir de las bases de las columnas tus elementos de fundacion: Vigas de riostra, pedestales, pilotes etc. Debes saber como sera la union de las columnas con los elementos pedestales: pueden ser continuos o en algunos casos articulados (Pilotes) de acuerdo a tus criterios.
2.- En el caso que trabajes con zapatas o placas, puedes dibujar estas placas en el ETABS. En algunos caso se discretizan y se les asignas SPRINGS para simular la interaccion con suelo. En cuanto a la vigas de riostra, en mi caso, nunca lo hago.
3.- En SAP o ETABS puedes conseguir las areas de acero de los pedestales y analizar tu estrutura completa. Tambien puedes conseguir los aceros de tus vigas de riostra o amarre.
4.- Tambien puedes exportar la base desde ETABS a SAFE para el calculo de tus elementos de fundacion. En SAFE puedes conseguir tus areas de aceros de zapatas pero no la de pedestales, para modelar la rigidez de los pedestales usa el comando STIFF en SAFE.
