EJEPLO DE DISEÑO DE UNA EDIFICACION DE ALBAÑILERIA CONFINADA
FFFFFFFFFFFFFFFFNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
vicaraneda
me serviria mucho...andaba buscando estome serviria mucho...andaba buscando esto
- arkigustavo
Muchas gracias excelente amigo, exitoo!!!
Larryciento
Gracias por el aporte esta bacan. necesito un diseño seguido paso a paso de un edificio con todo su calculo en exel y planos para mi informe de mi curso de antisismica.
elarquizorro
MUCHAS GRACIAS AMIGO POR EL APORTE, ME SERVIRA DE MUCHO
alidiachambilla
hola me gustaria contar con informacion sobre albañileria estructural
- jcoronellr
Saludos alidiachambilla
En este for existe bastante informacion del tema te recomiendo buscarla
Ing. Jaime
Ing. Jaime
[quote="marx"]FFFFFFFFFFFFFFFFNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN[/quote
Gracias por el ejemplo... no tendras un ejemplo de albañileria armada se le agradeceria................
manuel1971
Gracias, muy interesante y practico
abimael1961
buenas, por favor que alguien me ayude, porque no puede bajar algunos archivos, disk no tengo permiso, actualizo la pagina y nada, esperando pronta respuesta, estare muy agradecido.
Haroldsf
Debes identificarte con tu contraseña y nombre de usuario para que te aparzcan los archivos dispnibles para descargar. Suerte.abimael1961 escribió:buenas, por favor que alguien me ayude, porque no puede bajar algunos archivos, disk no tengo permiso, actualizo la pagina y nada, esperando pronta respuesta, estare muy agradecido.
waltercachay
gracias verificare
la informacion
la informacion
richardnunca
gracias por la aplicacion
