Acaban de liberar una actualizacion para el SAP 2000
Les anexo los alcances.
SAP2000 V8.3.7 is a minor update to V8.3.3 and is only available on the ftp.
CONTENTS
1. Installation Instructions for SAP2000 Version 8.3.3
2. Specifying Program Level for Version 8.2.5 and above
3. Installing over older version 8.xx
4. Updating older version 8.xx from the ftp
5. Updating older version 7.xx or 6.xx
6. Changes from Version 8.08
7. Release Notes for Version 8.08
The installation instructions are available in three places.
A. The "SAP2000 Installation Card" link on the SAP2000 CD browser.
B. A printed document included with the program package.
C. In the SAP_Install_Instructions_V8.pdf file in the root directory of the CD.
The instructions include information about the software protection system used and
installation options and instructions. You can choose between a Standalone or
Network installation.
For Network installations, see the "License Manager System Administrator's
Guide" for more detailed information about the License Manager and the License
Manager Administration program "WlmAdmin.exe".
For Network installations of version 8.2.7 and above you can create a text file,
Level.txt, and put the Program Level in it. Save this file to the License Manager
subdirectory of the SAP2000 directory. This file will cause the program to find the
license faster. Note that this file will be included when a new license is sent.
If you experience problems with the license please refer to the appropriate
"License Trouble Shooting Guide..." located in the SAP2000 folder.
If you have multiple SAP2000 levels (Advanced, Nonlinear, Plus and Standard) running
on a network you might need to specify which one you want to run. There is a "ProgramLevel"
entry in the SAP2000.ini file which you can set. The SAP2000.ini file is located in the
workstation's Window directory. The SAP2000.ini file takes precedence over the Level.txt
file in item 1 above.
Version 8.3.0 cannot coexist with another version 8.xx on the same machine. It will
first uninstall the older version from that machine.
Network installations contain a Setup for the license manager, SentinelLM 7.2.0.
If you are currently using SentinelLM 7.1.1 you should upgrade it to 7.2.0. First
uninstall the old version 7.1.1. Then run the Setup for the new version 7.2.0. To
register your saved license file, copy it over the one in the ETABS License Manager
directory and run "lslicense.bat".
The update from the ftp is not a full installation. Only newer files are included in
the zipped file. These should be extracted in the folder where the current program is.
The file gdiplus.dll should be copied onto the windows system or system32 folder unless
a file by this name is already present.
Version 8.xx can coexist with any version 7.xx and/or 6.xx.
Changes from V8.3.6 to V8.3.7 (03/16/2005)
- A bug that affected Auto Static Seismic Loads when
internal meshing was used has been fixed. Models
using this feature in the presence of internal
meshing should be reverified.
Changes from V8.3.5/1 to V8.3.6 (03/06/2005)
- V9 and V10 licenses now recognized.
- An updated Chinese Steel shape database is
included compliments of our Chinese dealer.
- Minor bug fixes.
Changes from V8.3.4/1 to V8.3.5/1 (10/21/2004)
- Minor bug fixes.
Changes from V8.3.4 to V8.3.4/1 (08/11/2004)
- Minor bug fix in shell element out of plane shear
reporting.
- Australian/New Zealand Steel shape database added
compliments of our New Zealand dealer.
Changes from V8.3.3/1 to V8.3.4 (07/11/2004)
- An error was fixed in steel axial hinge ductility
calculations. The error affected hinges that were
partially defined. Fully defaulted or fully specified
hinges were unaffected.
- Other minor bug fixes.
Changes from V8.3.3 to V8.3.3/1 (05/19/2004)
- A minor bug that caused recently opened files
not to open correctly from the File menu has been
corrected. The problem was only in V8.3.3.
The files always opened correctly when using the
Open menu item or the Open tool button.
Changes from V8.3.2 to V8.3.3 (05/04/2004)
- Reissued on CD.
- License installation instructions updated.
Changes from V8.3.1/1 to V8.3.2 (04/28/2004)
- Minor bug fixes mostly related to display.
Changes from V8.3.1 to V8.3.1/1 (03/04/2004)
- The Cold Formed Steel member design has been updated. This is still
beta. Import/Export of Cold Formed sections and member design data
is incomplete.
- The BAG bridge model generator has a minor fix. It was unnecessarily
further meshing in some cases.
- The Section Designer has been updated. Should now be faster for some
sections.
- A bug that caused erratic program behavior when concrete members were
added to a model after concrete frame design has been corrected.
Changes from V8.3.0 to V8.3.1 (02/27/2004)
- Some significant errors in bridge loading have been corrected. These
errors were present in versions 8.2.9 and 8.3.0. They do not affect
earlier versions. Specifically:
(1) The HL-93S load was not calculating negative moment in the frame
elements, nor axial forces in columns at interior supports.
(2) The HSn-44L load was using the shear rider for all responses,
including moment.
(3) Reactions at joints directly connected to bridge lane elements
were not being correctly computed for moving-load analysis.
- An error was corrected that caused failure to converge in some nonlinear
static analysis cases that include P-delta effects if the structure has
moment end releases in the frame elements.
- The Help has been revised.
- Cold Formed Steel member design has been added. This is
currently a beta version for this option.
Changes from V8.2.9 to V8.3.0 (01/29/2004)
- Reissued on CD.
- The Verification Manaul and Examples have been updated.
- Support for Frameworks Plus V7.1/7.2 has been added.
- Section Designer has been updated.
- A bug in the recovery of stresses for warped shells for nonlinear analysis
has been corrected. This only affected V8.2.9.
Changes from V8.2.8 to V8.2.9 (01/15/2004)
- P-delta force calculation in the frame element has been improved for nonlinear
static analysis and buckling analysis cases.
- Temperature loads on Frame elements now work correctly in large-deflection
nonlinear static analysis cases.
Changes from V8.2.7 to V8.2.8 (12/12/2003)
- The Direct Integration Time History Analysis has been reinstated in
the Nonlinear version of the program.
Changes from V8.2.6 to V8.2.7 (10/13/2003)
- A new type of Nllink property has been added, called "Plastic (Pivot)".
It is a multi-linear plasticity model similar to the "Plastic (Kinematic)" model,
but it dissipates less energy. The original Kinematic model is appropriate for
metals, whereas the new Pivot model is more appropriate for materials that
experience degradation upon load reversal. The Pivot model is currently based
on the popular Takeda model. In the near future, additional parameters will be
added that will allow more control of the type of stiffness degradation.
- The P-M-M frame hinge has been improved to better handle collapse of the hinge.
During hardening, plastic deformation occurs normal to the PMM surface, as before.
During collapse, plastic deformation occurs in the radial direction, either
(a) toward the origin if axial collapse is permitted, or (b) toward the P axis
if axial collapse is not allowed. The program may have to iterate (a lot) to force
this collapse. The analysis may fail to converge if axial collapse is permitted
and there is not an adequate load path by which to transfer pre-existing loads
(e.g., gravity) away from the element. If convergence cannot be achieved, you
may want to either (a) not allow axial collapse, (b) accept that collapse
is imminent and re-design the structure, or (c) consider a direct-integration
time-history analysis.
- Internal meshing of Solids is now enabled
Changes from V8.2.5/1 to V8.2.6 (08/12/2003)
- Minor changes to working of the license
Changes from V8.2.5 to V8.2.5/1 (07/14/2003)
- Minor changes to Caltrans BAG Modeler
- Step by Step design option for time histories now working
- Correspondence design option for moving loads now working
Changes from V8.2.3 to V8.2.5 (06/25/2003)
- Program version now determined from available license
- Frame Hinges now shown in AVI files
- Shell/Solid stress contours now shown in AVI files
- Solid and Link elements now included in Section Cuts
Changes from V8.1.5 to V8.2.3 (04/14/2003)
- Auto Wave load generation added (Advanced Version only)
- API Punching stress check added (Advanced Version only)
- Support for CIS/2 LPM6 added
- Support for Frameworks V7 added
- Panel Zone deformations can now be explicitly included
- An updated Euro.pro file is now included
- Italian Steel and COncrete Design codes added
- Korean Concrete Design code added
Changes from V8.1.5 to V8.1.6 (03/06/2003)
- A bug that affected Auto Seismic static loads in some cases
has been corrected. Models using this feature should be
rerun and checked
Changes from V8.1.4/1 to V8.1.5 (02/03/2003)
- A bug in the stress recovery of triangular shaped
shell elements has been corrected. This did not affect the
stiffness
- The BSShapes.pro file has been modified to correct the
plastic modulus. It was reporting the section modulus instead
Changes from V8.1.3 to V8.1.4/1 (01/28/03)
- A bug that caused Auto Seismic and Auto Wind loads not to work
in Versions 8.1.2 and 8.1.3 has been corrected
Changes from V8.1.2 to V8.1.3 (01/21/03)
- Line Constraint assignments to Area Edges are now possible
- Checks added in Section Designer for overlaps
- Minor bug fixes
Changes from V8.1.1 to V8.1.2 (01/10/03)
- Verification Examples for Shells and Links added
- Verification Examples for Frames updated
- A batch file is now included to run all verificaiton examples
- A *.xls file is now included in the Verification subfolder to verify
results from the verification batch file run. Instructions for
running the batch file and the comparison are included under Help>
Documentation> Verification> "Automating the SAP2000 Verification Process"
- Minor bug fixes
Changes from V8.09 to V8.1.1 (12/20/02)
- Named Set options are now available
- Energy Plots and drift optimization are now available
- Several minor bug fixes have been made to the graphics
Changes from V8.08 to V8.09 (10/23/02)
- Steady State and PSD options are now active
- Advanced Local axes for Nllink elements is now active
- Several minor bug fixes have been made to the design
- Several portions of the Help have been updated
SAP2000 Version 8.08 is the initial release of SAP2000 Version 8.
The pre-release/beta versions 8.00 to 8.07 are now superseded.
The following items are incomplete and/or disabled in Version 8.08:
- Panel Zones
- Named Plots options
- Advanced Extrusion Option
- Portions of Help
- Design Manuals
- Verification Manaul and Examples for other than Frame elements
They will be released as completed.
Se puede bajar en la paguina
www.morrisoningenieros.com
Que son representantes de CSI
Actualizacion SAP 2000 v 8.3.7
