[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios"
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035)
Foros Ingeniería Civil • Galpon Acero
Página 1 de 1
Galpon Acero
Publicado: Sab Nov 01, 2008 2:19 pm
por alaniss
hola amigos: necesito ayuda urgente con el diseño (para revision de un galpon ya construido ) de un galpon que tiene como perfil metalico en todos sus elementos del marco, dos defensa caminera soldadas............este galpon ya tiene varios años construidos y su construccion se ve muy solida.......yo calculo con el sap pero me da como resultado que la estructura no resiste en ninguna de sus elementos las cargas solicitantes........yo pienso que es porque no reconoce bien el diseño con aquel perfil.........lo trato de hacer a mano siguiendo la Nch 427 pero resulta que el perfil se pasa de los limites de esbeltez....mi pregunta es: como lo puedo hacer para realizar este diseño???
Re: Galpon Acero
Publicado: Sab Nov 01, 2008 3:31 pm
por PROYECTOR
alaniss escribió:hola amigos: necesito ayuda urgente con el diseño (para revision de un galpon ya construido ) de un galpon que tiene como perfil metalico en todos sus elementos del marco, dos defensa caminera soldadas............este galpon ya tiene varios años construidos y su construccion se ve muy solida.......yo calculo con el sap pero me da como resultado que la estructura no resiste en ninguna de sus elementos las cargas solicitantes........yo pienso que es porque no reconoce bien el diseño con aquel perfil.........lo trato de hacer a mano siguiendo la Nch 427 pero resulta que el perfil se pasa de los limites de esbeltez....mi pregunta es: como lo puedo hacer para realizar este diseño???
Saludos!, por que no publicas tu modelo de sap2000 mara ver en que se te puede ayudar?, con la poca información que das es muy dificil ayudarte.
Re: Galpon Acero
Publicado: Mié Nov 05, 2008 7:47 pm
por alaniss
hola...a ver si esta informacion sirve de algo para que me ayuden: el galpon es algo bien simple en su elevación. es un marco tipico. las columnas tienen una altura de 4.38 m y estan separadas a 18.6 m. la cumbre de la cercha del galpon, que se encuentra en la distancia media de la separacion de las columnas, es de 5.93 m. y los marcos estan separados a 6m.
las columnas y la cercha tienen un unico perfil (dos defensas camineras soldadas). al dibujar el galpon es solo una linea continua y con los quiebres respectivos: (de izquierda a derecha o viceversa)vertical hacia arriba, diagonal hacia arriba, diagonal hacia abajo, y vertical hacia abajo. y a toda esta linea se le asigna el mismo perfil antes mencionado.
como dije este perfil se compone de de dos defensas camineras de espesor 2.5 mm y las propiedades se encuentarn en la sgte pagina http://www.almarza.cl/defnsascamineras.htm.......ni siquiera me resiste el peso propio......... :(
gracias......saludos.
Re: Galpon Acero
Publicado: Lun Nov 10, 2008 2:36 pm
por amendinueta
saludos a los amigos del foro...
colega alaniss..puede darse el caso q algunos de los elementos..no cumplan con las cpndiciones de esbeltez fijadas en las normas y por criterio del proyectista se haya realizado asi...eso sucede mucho...no se puede ser tan rigidos a veces..verifica si por peso propio los elementos cumplen por resistencia...
ALEXIS
Re: Galpon Acero
Publicado: Mar Nov 11, 2008 1:24 am
por nassiul
Hola,
Publica el modelo. Siempre es mucho mas facil
