[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios"
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035)
Foros Ingeniería Civil • duda para viga: Frame o Shell?
Página 1 de 1
Publicado: Vie Sep 07, 2007 1:22 pm
por fenacles
Estimados:
Tengo que modelar una estructura tipo escalera... y entre losas o forjados de distinto altura tengo una viga que las une. Pero esta viga pasa para abajo un resto.
Ahora, como puedo modelarlo como viga?
como viga no me une las losas. Para lo que pense hacer shell.
Hay otra forma que se unan usando Frame?
Otra aplicación: para losas en voladizo, como balcones, con vigas en su perimetro.
en la uniones de los frame, ¿el modelo une los puntos inferiores de las vigas?..
pregunto esto por que en la viga mas externa se produce un momento torcional.
O se debe ocupar Shell?
SAludos y gracais
Publicado: Mar Sep 11, 2007 5:46 pm
por fenacles
Por otra parte obtuve la respuesta, la cual fue la siguiente:
No es bueno combinar los elementos shell con frame.
En el caso de una escalera:
las vigas modeladas como frame solo son lineales, aunque por geometria haga calzar con los point de la siguiente losa a conectar no lo hace, esto por que para el programa toma la viga solo como una linea con 2 extremos con esfuerzos.
Para solucionar la conección se pueden hacer rigid body, o elementos muy rigidos (E*I>>). Lo primero relaciona los desplazamientos, lo segundo puede crear problemas con las matrices que se genera.
Conclusión: Usar todo con shell, solo en casos donde la viga o viga invertida con solo 1 apoyo.
