[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description"
[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios"
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035)
Foros Ingeniería Civil • Mensulas cortas en Sap2000
Página 1 de 1
Publicado: Mié Jul 21, 2010 9:09 pm
por Pappusth
Hola!
Soy un estudiante que empece a utiliar recientemente el SAP2000. Tengo un problema para modelizar en un pórtico las mensulas cortas sobre las que se apoyan las vigas pretensadas de una estructura.
El problema es que cuando modelo el portico libero los extremos de los dinteles en la opción constraint para que no haya momento en los extremos de la viga. Dentro de esta misma opción te permite introducir la distancia a la que liberas la barra. El problema es que cuando le das a Run en los resultados no aparece momento en las columnas debido al apoyo en mensulas tal y como debería ocurrir ¿Qué he hecho mal en el procedimiento?. Si me pueden ayudar se lo agradeceria.
Re: Mensulas cortas en Sap2000
Publicado: Jue Jul 22, 2010 6:34 pm
por HectorPerezB
Compañero, con qué constraint estás liberando el extremo de la viga?
Bueno, lo que yo he hecho es:
1. Seleccionar el elemento, Menu-Assign-Frame-Releases, y ahí libero el momento; ¡claro falta la excentricidad!.
2. Selecciono nuevamente el elemento, menu-assign-frame-insertion point, y ahí defino el offset (la distancia desde el eje de la columna hasta el punto de aplicación de la reacción de la viga); y de está manera queda definida la excentricidad.
Espero que funcione.
Saludos,
Héctor Pérez.
Publicado: Jue Jul 22, 2010 9:00 pm
por Pappusth
Al final funcionó. Sólo me faltaba utilizar el offset con la excentricidad
Muchas gracias por la respuesta Hector
